Kyosho Inferno MP9 TKI4 1/8 Buggy Kit >
Like Tree321Likes
    Hide Wikipost
Old 11-05-2018, 09:06 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
Last edit by: 30Tooth
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Another option if you want TKI4 Durability but TKI3 geometry of the front arm is :
IF493 Front Arm (Updated MP9 front arms replaces IF427B as a direct fit. Left and right.)
They use the older TKI3 captured outer hinge pin and screw. But if you just reem out the the outer hole you can use TKI hinge-pin/nut (IFW458)
Optional Updates / New Parts:
IFW469 IFW469 Aeration Cap Set(Threaded Big Shock/MP9)
IFW473 New Brake Pads (Sept 2017)
Optional Alu front hubs:
- IFW412 - 13 deg (like stock plastic ones)
- IFW436 - 16 deg
- IFW474 - 17.5 deg
- IFW461 - 19deg
M2C 1mm engine spacer: M2C9610
Body Options
New Bitty Force Body
Tebo's Build Videos
Video #1
Video #2
Video #3
Video #4
Video #5
Video #6
Original Kyosho MP9 TKI Thread
_____________________
Baseline setups from Joonas.
Shock build with vented cap and compensator.
You have to use the HC diaphragms (if346-09,stock TKI3 and if not mistaken TKI4 too, yes the thin ones no one likes), aeration caps without the bleeder screw or mod the stock caps by drilling a 1.5 or 2mm hole on the top facing up or at an angle (doesn't matter the size or angle, it just for bleeding pressure behind the diaphragm and allow the foam compensator to breathe) and a 10mm width x 3.5mm height dome shaped foam compensator made from old open cell inserts or dishwasher sponge. The foam compensator has to be soft enough not to add rebound but allow the diaphragm to regain it's shape.
Setup Sheet and Tuning
The setup sheet is getting crowded with all options but don't worry once you get acquainted with the parts will make sense.
Run the car as is, more than probably you won't need anything else. Using my setup as an example:
Diff gear has two options, normal and LSD. LSD stands for limited slip differential and is like using thick oils because you can't tune coast from locked.
Shock setup is a bit more confusing, you have two shock body sizes (S and M and truggy sized rear shocks that only the first version had so forget this one), three types of pistons (flat holes and surfaces, flat holes tapered surface and tapered holes with tapered surface): tapered have most pack, then black(simple piston) and then white because length of the holes. Then you have different length springs to account for different shock sizes, for a standard wheelbase/no weights car a good combo is Light Blue front and Orange rear, if you extend the wheelbase then I expect the included Light Blue rear springs be money instead of Orange.
Ride height is self explanatory, start always with lower arms parallel because good suspension geometry will be far easier to achieve. Rebound is used as total shock length no idea why they call it rebound, either use total shock length or maximum exposed shock shaft length. Camber self explanatory, run more camber in the front than the rear to make the car oversteer and more rear than front to make it understeer(grossly oversimplified).
Toe same deal as camber(again grossly oversimplified) but this you have to run the least amount you can. I use around 2º-2.5º on my cars, never more as I can find traction by other means with way less impact on performance.
Wheelbase is a powerful setting, changes a lot of stuff. Let's just say that it can make the car behave neutral or not in that small range. Try for yourself. I like to use the longest setting and tune from there.
Shock position self explanatory, something most don't change and I don't play around with it. I do have a method but involves much work (with the car bottomed out, see which position places the shock 90º to the lower arm and then chose spring from a couple equations and bam done, I can do it easily so anyone interested just ask.
Rear upper arm position is again an important setting, you change both camber gain and roll centre. The rear roll centre should be higher than the front, that's why I use the middle hole inner row as a starting setup.
Suspension arm, self explanatory: there are two different length arms and each has a hard and a normal flex plastic.
Front suspension bushing is for upper arm alignment, also same deal as rear upper arm position changes both camber gain and roll centre.
Suspension holder is for kick up (pro dive is the correct naming). I believe tki4 9º of kick up to be better than 9º of kick up using the tki3 parts because you can run the car lower (26mm front ride height) and use the +2mm front shock tower if there's too much camber gain or it's stiff in roll. So use +2mm lowered roll centre to keep most stuff unchanged or use the bushings with the dot up to lower the roll centre a bit more, doesn't hurt anything.
Front hub carrier, self explanatory. I am trying to use the out hole on top of the carrier as it is better during braking and accelerating. Together with the higher front roll centre on the tki4 should provide enough camber gain during cornering if not then more caster will do.
Rear roll centre and anti squat(wrongly called skid angle). Again same thinking as the front, lower the car and keep roll centre in the same height as before(that will need a change in upper arm position which my setup does). Anti squat is changed only if the pitching motion causes too much camber to be gained by the rear tires on power, nothing more.
Front knuckle, apparently there's a difference in the Ackerman arm. Can't say anything about them as I don't know enough about both.
Rear hub carrier,there is one made of plastic (which doesn't have offset apparently so it's suited to long arm setting) and three aluminium versions. One similar to the plastic one, other with offset and a new one with offset and adjustable hub height.
Rear tread can be used as arm length and outboard toe(never seen it being used but the possibility is there). Longer is better most of the time (only on really low traction).
Chassis brace, wheel hub, sway bars and weight are self explanatory. No need to use weights nor other hubs. A couple of roll bars would be a nice addition. About the aluminium braces I am torn, I guess the car doesn't need flex with this setup but won't recommend the stiffer braces but the lower engine mount is very nice to deal with flex around the clutch.
Wing and wing stay are like the d81x had regarding height and position. The wing should be as low and have free airflow as possible.
Print Wikipost
Old 02-24-2016, 09:07 AM
Trader Rating: 47 (98%+)
Default Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
I thought this was interesting.
http://www.amainhobbies.com/rc-cars-...33001b/p488711
wichitafc98 is offline
Old 02-24-2016, 09:14 AM
Suspended
Trader Rating: 61 (100%+)
The new wing mount puts the wing WAY up there.
Cool looking car.
Socket is offline
Old 02-24-2016, 09:13 PM
Default tki4
I wonder if the new upgraded parts will be compatible with the tki3?
GIVITUP is offline
Old 02-24-2016, 09:26 PM
mourinho's Avatar
Trader Rating: 46 (100%+)
i'm certain they will be
mourinho is offline
Old 02-26-2016, 12:47 AM
If it is anything like the previous kyosho cars it is sure to be a winner
aussiercracer is offline
Old 02-26-2016, 07:29 AM
Tech Prophet
houston's Avatar
Trader Rating: 96 (100%+)
All tki4 parts are bolt on to tki3
A few geometry changes but very close to same car ,mp9 is awesome
houston is offline
Old 02-26-2016, 11:53 PM
Cody King appeared to be running the TKI4 at DNC. Or at least certain TKI4 parts.
Old 02-27-2016, 12:04 AM
His facebook post said he was running a stock tki3 kit, with the tki4 wing only
Gavel is offline
Old 02-27-2016, 12:13 AM
Ok, didn't realise. A video on neobuggy suggested he was running a couple of other things as well.
Old 02-27-2016, 01:41 AM
I'm hoping for $200-$300 we will be able to upgrade...
black blood is offline
Old 02-27-2016, 01:56 AM
rather than spending $900
Old 02-27-2016, 03:38 AM
neumatico:
mauro67 is offline
Old 02-27-2016, 03:46 AM
Cool looking car.
Yup that wing is pretty high up there, wonder why i thought the lower wing worked better.
BiLL77 is offline
Old 02-29-2016, 03:20 AM
I think its $1049 with the current exchange rate..
Old 02-29-2016, 12:37 PM
Motorman007's Avatar
Trader Rating: 89 (100%+)
http://shop.microracing.se/bil/kyosh...ferno-mp9-tki4
Motorman007 is offline
